Tha’ToneSeaQr
Hey guys, Before I just impatiently solder the potentiometers to the PCB I thought I’d wait a beat and make sure I’ve got the mounting right.. So if I’m looking at the top (component side) of the main board w/the in-gnd-sw-out markings being the bottom. Which direction should the potentiometer body be facing on a 4-pot board?? Towards the bottom or towards the top of the PCB??
**One other quick question about the in/out jack wiring. Which wire is the tip which is ring? In other words which wire location ie; top of the PCB and bottom/from the switch.. For example Top=Ring Switch=Tip or vice versa…
Thanks in advance!!
Thanks in advance!!
