More than "a few" - less than "a lot" - let's call it... "several"How many 201's do you have?
So... I need the 75? (Please say yes...)
Thanks for the explanation! I'll just go with whatever the highest I have and go from there.The two originals measured were -0.84V and -0.95V, both used the same values for RB1 and RB2 (6M2, 5M1 respectively).
I've gotten acceptable results with anywhere between -0.65V to up to -1.3V without needing to change the resistor values at all. If you get too far out of that range you'd need to start compensating the voltage drops of the diodes / LEDs in the compression circuit.
The Ultimatum isn't quite as critical as the X100 because it doesn't have a clean tone. Biasing the X100 is a bit more involved because you have to find the sweet spot where you get the right amount of compression with no clipping.
If you want to get extremely precise you'll need a scope, signal generator, and to hand select the forward voltages of the LEDs. I personally feel like this is overkill for this one.
Then it shall be done. Guess this’ll be one for a 1590BB2That wouldn't be a terrible idea. I think some folks might actually prefer the compression disabled.
Unfortunately, those testers do not adequately measure JFETs. Those testers will not display the Vgs(Off), Vgs(on), R(On) and several other specs. The Vgs(Off) spec value is what needs to be targeted for the JFET. If you want to get serious about testing JFETs, a Peak Atlas DCA75 is the way to go. It will also display all the important Si & Ge BJT specs - distinguishing between Si & Ge and exposes any measurable "Leakage" values.My tester measures Id and @Vg I’m not sure what uA it uses to measure. Would this be something I can use for this? So far nothing I’ve measured has gotten close to 1.0v they’re mostly close to what’s shown in the picture.
Would bypassing that portion of the circuit have any effect on the sound of the pedal?
