Just finished the send/return on my Skeptical Buffer and wanted to share for anyone wanting to add one to their build.
I had success with (1) Switchcraft Shunt jack and (1) Switchcraft Mono jack.
The Shunt jack let's you connect to the other side all the time. Unplugged, the shunt jack shunt terminal is connected to the tip of the Mono jack. When a cable is plugged into the shunt jack, it disconnects the Shunt and connects the tip like normal.
You should measure well and not use Lumbergs like I did. I initially tried to use a TRS as a shunt, but had no success.
I had to bend the terminals of the jacks inward and set them at a specific angle to clear the board, diodes, and surrounding caps.
I also soldered the jacks in the position they would be installed as.
For the send/return I used RobRob's 5E3 FX loop diagram:
It was a really tight fit so I ratcheted down the jacks so they wouldn't move.
As you can see those bottom outer caps are bent a little.
Here is what it looks like close up.
PLENTY of space!
Here is the foot switch:
![Screenshot_20230628_033930_Adobe Acrobat.jpg Screenshot_20230628_033930_Adobe Acrobat.jpg](https://forum.pedalpcb.com/data/attachments/51/51301-369b6673e1424e131a25263acd2393eb.jpg)
![Screenshot_20230628_033340_Gallery.jpg Screenshot_20230628_033340_Gallery.jpg](https://forum.pedalpcb.com/data/attachments/51/51302-282d9c95bb720c8d0435e7d7c0d3b700.jpg)
![Screenshot_20230628_033332_Gallery.jpg Screenshot_20230628_033332_Gallery.jpg](https://forum.pedalpcb.com/data/attachments/51/51303-a385d52f736fd7b75161e3143c068d6b.jpg)
![Screenshot_20230628_033325_Gallery.jpg Screenshot_20230628_033325_Gallery.jpg](https://forum.pedalpcb.com/data/attachments/51/51304-2ac87a6d8cbfb1882d787a3068b8e7a8.jpg)
PLENTY of space!
![Screenshot_20230628_033309_Gallery.jpg Screenshot_20230628_033309_Gallery.jpg](https://forum.pedalpcb.com/data/attachments/51/51305-cf62ae8f9a7835f4eaa0724255a47d7e.jpg)
