But seriously folks...
The description states: The Muffinator Fuzz is identical to the PedalPCB Muffin Fuzz, with the addition of switchable diodes in each clipping stage.
In other words, 95% of the BOM can be found in the Muffin Fuzz build docs.
The two toggle switches can be either ON/ON for selecting one diode pair or the other, or ON/OFF/ON gives a 3rd choice: no clipping diodes. I recommend ON/OFF/ON for the switch on the right (when viewed from the front panel).
The diode footprints imply that D5-D8 are intended to be Germanium diodes. Warning: 99% of the Germanium diodes you'll find for sale are too leaky to be useful in a BMP. Whatever you buy, you'll have to test them. Don't bother with Russian Germanium diodes, they are all too leaky. A good alternative is low-leakage Schottky diodes. IMO, you would be better off using red LEDs for D5-D8.
Red leds are fantastic in a muff. 4148’s compress and give so much “hair” do you really need more that a germ or work alike would. Red led’s with the off option as chuck suggests are perfect for a 2nd option to me.
And the part #s in the Muffin Fuzz carry over to the Muffinator as well (except for the additional diodes which Chuck already mentioned).
Also, check out this post by @Robert for the switch orientations:
