So, what I want to do is use a relay bypass to switch between two always on effects. I've worked out how to do this with Paulinthelab's relay switching here:
by cutting at T4 and hooking the other effect in/out along opposite sides of the t-row.
However, this layout only works on a single "pulse" to engage and then disengage. What I want is for it to also engage while the switch is held down. Can I use one of the relay pcbs here to switch between two boards - I see that they can either bypass or engage but I want to "bypass" to another effect. Is there a cut I can make on the board to enable this by wiring the "bypass" to the pins on the relay?
Soft Latch True Bypass (Relay) Switch For Guitar Effects Stripboard veroboard Layout
Electronics Projects For Hobbyists Makers And Hackers With Stripboard Layouts
paulinthelab.blogspot.com
