1590XX Request 2 Pedal PCB Kliche in one box
I tried to look and it just took me to a blank template. You have to use the share link from the drill templates home page.
That works.
Just at a glance the knobs look pretty far apart. I will have to look at it later when I am at home and can actually do some measurements. Also the LEDs for that board are mounted towards the top not the bottom. You would have to wire them off the board to put them where you have them. If that’s what you are after then great. On a standard ppcb 3knob board the top two knobs are 33mm apart. The middle knob is 25.4 mm below it and centered between the top two. Im on my phone at the moment so its kinda hard for me to dig into it.
So i guess the big thing here is what do you want to accomplish? Do you want to use all the pots as they are meant to be used, board mounted? If so then your numbers are off. I can work something up but it will take me a few days most likely. I may be able to do it tomorrow but no promises.
