They should work… but I downloaded the Jera one a while ago and never even got it to guess a value. It kept telling to put the apps against a white background. Literally, all I had was a white sheet of paper on my workbench and never got off the “instruction“ of needing a white background !Have you guys used any app that use your phone’s camera to tell you resistor values? Something like this? Do they work?
Yup! I’ll test every resistor and capacitor with a TC-1 (actually my second one, first one died after a year). Diodes with a DMM and transistors with a DCA-75. I’ve tested hundreds of resistors and caps and don’t think I’ve ever found one out of spec, but it’s just so easy and quick to test prior to installation. Also one more step to make sure I’m installing the correct value.I find my little TC-1 the handiest way to test resistors and caps. The zip socket stops them moving around. It’s pretty quick.
I never used to, and now I can't put anything into a board without testing it. Time saved later tracking down a bad part...Yup! I’ll test every resistor and capacitor with a TC-1 (actually my second one, first one died after a year). Diodes with a DMM and transistors with a DCA-75. I’ve tested hundreds of resistors and caps and don’t think I’ve ever found one out of spec, but it’s just so easy and quick to test prior to installation. Also one more step to make sure I’m installing the correct value.
Happy to help. Send them to me, I’ll test them with my DMM…I use a DMM to quadruple or quintuple test resistors before putting them in the PCB. I need help.
Does your TC-1 do IC's? The one I have doesn't but I could have sworn the listing said it did when I bought
