270Ω + 470Ω gets you to 740ΩThe ONE component I forgot to order for this Dung Beetle build is a 750R resistor. I know with tenting resistors, you can get within ballpark range of the desired value even if it's not the EXACT number. Can I do that sort of thing with any of the values I have on hand, listed here?
*Counts with toes....*680Ω or 820Ω
Ummm, not to be picky but that picture is only 477 ohms....Graphic from another thread; Just sub in your values:
270Ω + 470Ω + 10Ω = 750Ω
READ THE TEXT!Ummm, not to be picky but that picture is only 477 ohms....![]()
270Ω + 470Ω + 10Ω = 750Ω![]()
If I were you, I’d put 750 1r resistors inline and be golden. You know, just to be dead on. Also, I’d measure each one and verify they’re exactly 1 Ohm.
You’re welcome.
Uh, yeah, that's it. Lack of sleep. No longer partake so can't use that one.When something similar happens to me, I always blame sleep deprivation — and in all too many cases, it's absolutely true.
Do you partake? Maybe tipple a little? Those are good for blame deflection, too.![]()
A bit of salt for the wound? You guys are ruthless LOLThat's a 330K resistor.
