Absolutely! The 47pf will work just fine!Thanks! I thought so, just making sure. Second question- pcb calls for 2 51p caps. I have two 47pf monolithic. Would it work?
Eh, that might make it blow up.Thanks! I thought so, just making sure. Second question- pcb calls for 2 51p caps. I have two 47pf monolithic. Would it work?
Is over or under original value better?
Look at that 1/4W being an awesome big buddy giving little buddy a piggy back ride!Especially if you use 1/8w resistors as the little buddy riding on top
(And no I’m not making a 470r with those values.)
I think I've done the teepee myself when putting two resistors in series from the get go, but I don't think it really matters that much either way. If you care about the looks, do what looks best for you.I read about the "teepee" method of putting two in series. SMD or otherwise... Is there any best practice to this? I would think a "bridge" (the shape of a staple) formation with two hooks making the initial connection and have the two resistors stand up right, would look best.
Everything is an antenna. But as you said unless you have a high gain circuit or poor shielding it should be fine.Looks good to me.
Also made me wonder at what point do the bridge-lengths become antennae?
I can't imagine a couple being a problem within an enclosure, unless it's a super-high-gain circuit.
If I remember to do so, my next high-gain build I'll socket a few resistors and experiment with lead-lengths.
