was thinking the same thing. one of those solder tips I would never use and melt the plastic around the pins. work from there.Better to destroy the switch than the board. Do what ya gotta do.
Not worried. I'll be ordering the switch from you soon. Thanks.Nice! I think this is the first build report for the rotary version.
Removing the rotary isn't that bad if you aren't worried about salvaging it. (it probably wouldn't be reliable afterwards anyway)
Just clip the leads and then desolder them one at a time once the switch is gone.
The tricky one would be the center one.... After all the others are clipped I'd probably heat that pin and gently pull the switch off the board.
I'm trouble shooting my 2020 Roboto right now. Everything looks good so I'm a bit stumped. Sound in bypass, no light or sound when switched on. Noob question... Is it possible I installed the Rotary Switch backwards? It fit 2 ways, I figured it'd work either way. Was that a bad assumption?
