Here is a unique Boost with a bit of grit!
I have the standard 2 knob version also that I built years ago!
It uses a pair of LND150n3-g transistors for the gain stages.
This is a modified version of the Spaceman Saturn V Pedal to have a Tone control.
I contacted Chuck D. Bones who found the Schematic & modified it to suit my request, THANKS Chuck
I have removed the Fat Switch from my Build & settled on 15nF as a fixed value.
I also included Ferrite Bead diodes on the Power & Input (fairy dust on original design)
This was designed In House using my Eyelet Board design.
The Graphic is printed on A4 clear Adhesive back Sheet & sealed & finished in Automotive Clear Coat on a Tayda 125B Plain enclosure.
Here is the Schematic by Chuck D, Bones
With the Fat switch, you can also create a Treble Boost by adjusting the Tone control to suit :
