Yes of course!are you making the wooden boxes and taking them to your printer to get the laser etching?
Beautiful work. Also nice to see the shielding on the inside of the boxes.Yes of course!I make wooden boxes myself from start to finish. I only do engraving in the printing house.
I use project Tech 12 bass driver (PCB by 12afael)
Only change on this PCB is that i use TLC2264CP for IC2!
XLR wiring (balanced output) on that schematic is wrong (pin 1 goes to ground not pin 3) and DPDT bypass wiring (SW1, SW2 and SW3 on the schematic) must be wired corectly with LED and ground wire to be able to turn the pedal on and off!Gotcha. Thanks! I'll have to look into that project.
I do most of the work by hand. From cutting the trees in the forest to the drying wood a couple of years at my place, .. only electric tools that i must use are wood saw, the stationary planer for precise, rapid thickness planing and straightening, ... than i use hand milling machine for deepening the box .... edges of the box i shape by hand with wood files ... sandpaper for pollishing surface (from 120 to 3000 grit) ...Very nice! Are you hand carving these or are you using a router/cnc?
