SillyOctpuss
I want to build a Sandspur without a sundial. Can I jumper pads 1 and 3 of the sundial and then just use the internal bias trimmer?
Yes.I want to build a Sandspur without a sundial. Can I jumper pads 1 and 3 of the sundial and then just use the internal bias trimmer?
Cheers. I just went ahead and chucked the sundial in anyway. I tested it out with some bc183 and bc109c. Sounds great and so far I prefer the bc109c but I've got a load of different transistors to checkout. I've had most of these for about 7 years now and haven't used any of them.
Nowhere near as good as the germanium sunflower I built last week. This is the only the second silicon Fuzzface I've used in my life. I've never got fuzz and avoided it like the plague for the last 28 years until last week.
I've got some Bc108, 109b, 2n2222 and a load more transistors to try out on it. I've not mucked around with the bias either. I just set the bc183 and 109 to 4.5v on the collector of q2. My goal for tonight was just to get it populated and make sure ai was getting some fuzz from it.
What are the gains on the BC109C you have in there?
I think they're about 470 q1 and 510 q2. I just checked hfe on a few and threw these in to test it was working. Would you have any suggestions or recommendations for hfe? I'm assuming I would need to go for bc108 with a lower hfe if I want decent cleanup?
Any help would be appreciated I know very little about fuzz tbh.
I used some 2N2212 in my Twin Face and they turned out glorious. "Almost" the same as the the Ge side. They were pretty low gain, but I'd need to test them again to check the actual range.
I did a short video today showing the dynamic range I get with a Fuzz Face and the control set on my Les Paul.
I start with the neck pickup in parallel and the Bass Cut up with the volume on the guitar around 6.
This is my spare parts Fuzz Fave with BC547A Q1/Q2 at 285 hFE. I also have a 10 ohm resistor in series with the wiper of the Fuzz pot so it doesn’t go to maximum and I can turn it all the way up ().
Pardon the other effects. I had the El-Cap and Flint on so it was a bit washy.
What amp are you using in that clip? As great as the El-cap and flint are it would definitely be easier to make out the detail with less of the other effects.
I've just spent the last 30 mins playing American woman over and over on repeat working out the lead parts. I've never been into fuzz so now I need to learn all those classic fuzz tracks I didn't bother learning before.
Sorry I missed this. With the germanium I built last week the fuzz pot was up full and it was dialed back a bit with the silicon unit tonight.Do you keep the Fuzz knob maxed out or do you turn it down a hair? It makes a big difference in the cleanup.
For silicon I also like hFE around 250
I'm a total newbie, what is a Pugh range? I'm wanting to do the same thing, omit the sundial and just have a two knob fuzz.Yes.
Although adjust the trimmer value or make sure the internal trimmer has a Pugh range.
