Hello! I recently built a Seabed Delay, but all I'm getting is a dry signal. Soldering is clean and saw a forum post about a difference between the build doc and the PCB, but I soldered according to the PCB (although the build doc lines up with the PCB). Is there a known issue with the board that causes it to do this? I measured the voltages at all the pins on both the PT2399 and TL072 (as another forum post about this board recommended) if that would help. I'm not sure what's wrong - the potentiometers, an IC or a resistor? If anyone has any experience with issues on this board and could help me troubleshoot that would be awesome. Thanks!
Also, I attached a picture of my soldering. It would be awesome if the whole issue is just a fixable soldering issue, but I've looked over this board so many times that I would actually be blind if I didn't see it.
