Sell Me Some Transistors for a Tone Vendor?
yazooligan
1x OC75
2x 2C381 or 2SC381
Just want to wrap this one up. It’s been sitting on my bench otherwise populated for months. I’m in Nashville. Thanks.
1x OC75
2x 2C381 or 2SC381
Your request is actually a bit more complex than it would seem. You'd have to find someone who has already matched and sorted the transistors for the MK I.
2C381 are RARE these days. OC75s are actually pretty easy to procure but are getting expensive.
I wouldn't worry about finding the exact transistors but rather hitting the right gain and leakage numbers. Places like Pedal Hacker have a good selection and are a trusted seller and probably your best bet if looking to buy individual transistors. I'm not sure if the Small Bear store is still open but they would be a good resource as well.
Am I looking for equivalents at Pedalhacker? I don’t see either of the ones from the build doc on their site. Smallbear is still open for now but I think they’re sold out of the ones on the build doc.
You won’t get MKI from Pedal Hacked. His Ge stock currently is low leakage Russian.
Thanks for the clarification. I just know they tend to have more GE in stock than other reputable places. Small Bear is really drying up the place, it seems.
Everywhere is drying up. There are certainly some big caches of NOS devices still out there, as evidenced by some of the bigger hauls made by djlavalamp at R2R recently and of course many of the other reputable builders of British Fuzz, but the sources will continue to dry up for us Joe Schmoes as the availability decreases and sheer capItal required increases.
I bought a collection of >200 old transistors from eBay and picked through them to find the correct spec’d gain and leakage for my tone bender build. It’s a bit of a pain but it’s a very picky circuit. I played it a bit tonight and it sounds immense so it’s definitely worth the effort!
I just got three MP-40A’s from eBay and the seller says they’re matched, so I’m gonna try to put all three in the Vendor and see what happens.
What would you say is a good/bad ratio in buying in bulk?
It worked!
I’ve only tried putting in three MP-40A’s all with the same leakage. I might try switching in one or two with higher leakage to see if that affects the sound. As it is, the sound is very big and full, but not as high-gain as an original. You can max the volume and attack and still not have a ton of screeching feedback. Seems like an improvement over the original to me.
