ShamWah - inductor
toto_
Hi guys,
I'm building the ShamWah pedal, I bought this inductor :
but the pins don't match the pcb's pads. Should I cut the 6 pins where there is no wire soldered to and solder the 2 left on the pcb? But on which pads (schematic says pads 1 and 4)?
Thanks
Looking at the trace there, I think you just make sure the 2 pins on the transformer with wire leads to them are EAST/WEST oriented.
Not sure it'll help : IMG_20211102_113841.jpg
I think I found the answer by looking at the trace and the inductor doc (I should've added more details when I found the answer...)
Sorry for reviving an old thread. Out of interest, would one of these halo inductors fit inside a normal 125B enclosure? The PCB in the design I'm dreaming up would be mounted via input/output jacks so it could be set pretty low.
