mkstewartesq
Hi, all:
I'm getting some LFO ticking in my chorus (Aion Azure); I've unboxed it and the only way to make it go away is to move the input output cable much farther away from the board than is possible when the effect is in the enclosure. This tells me I should have used/need to replace with shielded cable. Can anyone recommend some and a source to purchase? When I search in most online places I just find wire that I don't think is what I'm looking for (e.g., 4 wire cabling). It's probably going to be best practices for using shielded wire in my next couple of builds anyhow (flangers/phasers, etc) so I might as well stock up.
Side question- as a stop-gap measure until I can replace the wiring, would it work to use copper foil tape on the input output wires, grounded at the jacks?
Thanks,
Mike
Thanks,
Mike
