So I've tried building this https://www.pedalpcb.com/product/pcb465/ and had immensely shitacular luck so far. 1st board, something happened at Mouser's website I get 75% parts as size 201 instead of 805. get new batch of parts put the opamp on backwards, not much info which end was pin 1 for the make I used >< smoked the chip, try to be cheap saving parts, I pull the traces off the board, but think that was from while trying to clean the flux I accidentally grabbed the acetone instead of iso for 2 swabbings... may have dissolved the lamination glue. Get new board, couple times I've found an end cap missing off a component...
Now I can't get sound with effect o. it appears I have all connections made/soldered. Works fine in bypass triple checked tip vs sleeve for the jack wiring, led lights up, no beuna. I'll add in pics after I've had a semi decent nap. Dear proprietor is the build document ever coming out? should I just write the whole fiasco off as lessons in smd soldering?
