Soft switch bypass help
I genuinely gave effort in searching previous posts, but could not find any without being further confused.
I have a customer asking for "soft bypass" switches in his requested pedal.
I am not sure which relay board I need or which switch either. Other searching tells me to use "momentary normally open" switches.
Would someone be so kind as to post a direct ink to the footswitch I need and the PedalPCB relay board I need to add the soft touch bypass switches for the pedals. I am placing a Tayda order soon, so Tayda supplied would be great or StompBoxParts would work also. None of the current builds are buffered bypass.
Thank you.
Thank you.
This is the board you need.
Any SPST momentary soft switch will work.
I use these from Amazon.
DaierTek 13pcs SPST Momentary... https://www.amazon.com/dp/B08TBTWDYV?ref=ppx_pop_mob_ap_share
Edit: Also you’re going to need the relay module, I’d just get it from PedalPCB.Com when you order the boards. You’ll also need some NE555P clock IC’s.
