SOLVED Solder pots - not PBC mounted
CinPA
First time here so please bear with me. I tried multiple searches and couldn’t find the info I needed.
Working on the Sandspur Fuzz and I only have solder type pots, not PCB mounted ones. I’m guessing that the square pad on the PCB is for the number one lug. Am I correct? If not, please set me straight.
Thanks in advance.
Correct.
The PCBs are designed to be mounted in the enclosure with the component side facing out.
See @MichaelW's build report for an example: https://forum.pedalpcb.com/threads/sandspur-fuzz-analogman-sun-face-bc108.12483/
img_3197-jpg.28616
Reactions: Nic
