I just finished up a kliche mini build - there is little to no gain and the dual gain pot seems to function in reverse (louder when turned down and quieter when turned up). The diodes are mounted a little weird because the glass casing on these is easily broken so I left the leads a little long. I have verified there is no contact between the diodes and neighboring resistors with my meter. Everything else functions as it should. Treble works, gain works and the volume and treble pots have a plastic casing for insulation. It sounds like a klon but with much less gain so im hoping the issue is minimal. I have checked it against an identical board i built a few months ago and they are identical (all resistor and cap values are correct as far as I can tell and the pot values are the correct b10k and b100k). I can not see any issues so I thought I'd ask for some thoughts / leads. You guys have never failed to help me troubleshoot an issue. Appreciate the input. Let me know if you need any pics or additional info.
Here is a link to a clip of the sound issue and knob behavior:
I have also attached a copy of the original kliche mini layout for reference
Some general info: The kliche mini is 1/2 of a dual pedal containing a Pauper overdrive. Both pedal are connected to the same power supply but the signal paths are connected to a pair of separate in / out jacks for each pedal (4 total). I am only testing the kliche half of the pedal when I experience this issue.
