Hi All,
First off, thanks for this forum. Just started to build some pedals for my son and I to use and it has been a really fun learning experience. I am definitely a newbie so this is probably a basic problem but am not turning up anything obvious from searching.
I have two problems, with videos of each below:
1) when I use this with the 9v DC output of my Joyo power supply 2 I get buzzing in the effect and bypass modes, with slightly different buzzing sounds in each.
2) when I use this with a 9v battery input I don't have buzzing but don't really get an effect
I used a volt meter to confirm voltage for both the battery and the power supply (both 9v), although I'm not sure how to test of the supply is AC. I don't think so, it says DC and works with all my other pedals. I made an audio probe and tested my way through all the components on the board (helped me solve a previous problem) but am not finding any bad connections at the moment, just not much effect!
Wrong component choices? Wired wrong? An embarrassingly basic mistake? Photos of the build below.
Thanks!
Thanks!
