jeffwhitfield
Ok, just completed a FreakZEQ build and...well...there are some issues with this one.
First, the drill template is off. Specifically, the middle EQ switch is lower on the template than what the PCB allows. Has to be dead center of the four pots. Ended up with a bad hole in my enclosure. Not the worst thing to happen given that this is just a personal build.
Second, the 60pF capacitor is hard to come by at the moment. Only version that Mouser had available was a surface mount version...which can be used, but not easy to deal with. I socketed the thing and tried using a 56pF instead. I did try a 60pF surface mount...but wasn't sure if it really was doing anything. More on that in the next part...
Lastly, it just doesn't seem like the effect is doing what it's supposed to. A sweep of the Frequency knob doesn't seem to effect the frequencies in the same way as the Son of Kong pedal, which is what this one is based on. In fact, turning up the Gain and Q all the way and sweeping the Frequency knob results in some really funky sounds. Doesn't sound normal for sure. Just not sure how to go about debugging this thing given the weird nature of the build.
Can provide photos of my build and whatnot. Just throwing this up for reference purposes to start the conversion with. Anyone else build this one with success?
