Something like the Carbon Copy
Ultimately I decided to go with the Seabed. I think it’s the most pragmatic choice. I’ll save the BBDs for someone who cares.
Does this circuit fix the delay chip lockup issue this circuit has had in the past?
I agree with all the Deep Blue suggestions. It’s excellent.
I made an Fv-1 approximation of the Deep blue delay circuit. The actual repeats are handled in digital, but all the surrounding circuitry that imparts the EQ/tone follows the deep blue circuit. The main benefit for your use case would be long delay times (~1sec) with no degradation. I included the modulation knob which was one of my main goals for the project.
I could probably send you a pcb if interested, but it’s set up for 1590B side jacks.
I wasn’t aware of that issue- I have no idea. I’ve only built one Seabed before for my bass player, and he hasn’t experienced an issue with it. 🤷‍♂️ I did a quick search on this forum, but so far only found mention of lockup in a 2399 chorus Chuck experimented with.
This is awesome. You nailed a sweet spot for a DIY delay.
I won’t judge you for it! I still have yet to build a pedal with side jacks. There’s several Madbean projects I’d like to build that are designed with side jacks. I tried fighting one of the layouts, but I think I’m ready to give in and give it a chance.
I don’t remember having this much trouble with finding a good pt2399 the last time I made a seabed.
I have 10 of them here, and I’m struggling to find one that doesn’t have that light fizzy noise on sustained notes, or doesn’t motorboat on the max delay time.
I have a dm-3 board populated, but the “mix” and “delay” controls are swapped compared to the seabed layout. Which means if I pivot that way, I either print another enclosure, or fly the leads.
Maybe I just need to get 10 more pt2399s? 🤷‍♂️
I have 20 each of the SMD CD2399 and regular pt2399 coming from lcsc sometime in the next month (I hope, because I’m moving for July lol). Comparison time! And I can make use of this ridiculous cramped footprint I’m trying out 😂
Definitely interested to hear how the SMD CD2399s work out for you. I wonder if they’ll be more consistent than the through hole ICs?
