SOLVED Son of Ben No wet single
Hansvink
I recently built the son of Ben, light turns on and bypass works but no wet single.
All transistors are baised to 4v, single goes trough q3 tested with audio prob on q3 gate
If you're getting signal through q3, there not much left to mistake on the board.
Do you have signal at the out pin on the PCB.
If not, check resistance of out v. ground.
Can't see what's happening on that switch with the cloth everywhere.
If you're getting through q3, I would suspect it's a wiring issue or the switch is smoked.
Single does not come trough q1 and q2 just when I connect the gate of q3 to input
That cloth wire is so big, it’s hard to tell but it looks like your out jack is wired backwards. Also, one of your jacks need to be grounded to the stomp, not to the other jack.
