Spatialist Reverb Distorting Notes
jaysharpwilliams
I'm getting slightly distorted notes occasionally. It mostly sounds great but there's some static or clipping going on when higher intensity notes are played. Is there a way to reduce input gain or does anyone have an idea of what may be going on?
On the extremely off chance that either of you are still struggling with this 2 years later.... I just built an Octagon and had a problem very similar to the video clip that @Elktronics posted. In my case it was an incorrect resistor value (100K instead of the intended 100R @ R8). Swapped it out and the weird static on firmer picked notes (and a bunch of low level background noise) went away.
I've gotten few bad batches of TL072CP opamps from Tayda that exhibited a similar issue.
KNOWN BAD TL072CP DATE CODES from TAYDA:
18MDSHY
14AP8NM
07A5L8QM
