I just drilled a larger circular hole and it worked fine for me. I will post a picture of it later today if you want?
A triangle bit on a flat side will suffice if I don’t have a square file? Or should I try to get a square file that’s big enough to fit the round hole?Drill a hole Central to Hole required to fit a small square File in & remove the corners.
For Rectangular Hole, Drill 2 Holes & Remove excess with a Flat & Square file.
Be sure to Drill a 3mm - 1/8'' pilot hole before using Final size Drill bit
