mkstewartesq
So, a couple of things people have probably gleaned about me from my prior posts: first, I had never picked up a soldering iron before February 2023; and second, I am a big Brian May and treble booster fan. So far I’ve built about five boosters and like all of them for a different reasons, but they’re just taking up too much space on my board that I could use for other types of pedals. I’m also expecting to get a wireless system as a gift this Christmas.
Given all that, I decided to build a strap-mounted treble booster so that I could still get “the sound” while taking all of these boosters off my board.
This was more of a proof of concept; I think I’m gonna try again with a smaller enclosure now that I know how everything is laid out and how much space tolerance I have.
Thanks for looking, and sorry for the number of pictures.
Mike
- I started with a tiny Fuzzdog Treble Boost Deluxe board and modified some of the values to better match those used with the BC149 transistor, which is the transistor used in Brian May’s 1980s Cornish booster. I didn’t have any BC149s, but the BC239C is a pretty close match if you keep it on the lower end of the hFE range. I ended up going with an hFE of 512, and probably would’ve gone even lower if any of my transistors on hand had a lower hFE. The case is just a project box from AliExpress.
- I’ve wired this up with a USB rechargeable 9 V battery so I can just plug it in and recharge whenever needed, and also an LED because I am a forgetful soul and I’d like some visual indication that I have forgotten to turn it off. I used a 3PDT toggle switch between the battery and the power to the board because I wanted the power switch to not only disconnect the battery and LED when off but also allow for true bypass since this will always be on my strap with the wireless hooked into the output of the booster. One note about USB rechargeable batteries – I had a devil of a time finding a brand where the USB charging port did not inject unacceptable noise into the signal. I finally found some under the Reacell brand name on Amazon that are dead quiet.
- I hardwired the input cable from the guitar and then covered it in shrink wrap and molded it to match the curvature of the guitar. Not only does this give it a better look, it will hopefully also avoid any damage to the guitar from a cable slapping into it repeatedly.
Mike
