Fama
First off, I apologize for the abomination of a build. I first put in the 2N5088 in the wrong orientation, clipped off the legs and tried desoldering for a bit, but it didn't work very well so I just soldered a new one on top. I also subbed two of the 1uF coupling caps (?) for 470nF due to lacking 1uF parts. And finally C100 is two 4.7nF caps instead of a 10nF cap.
So, I'm not getting any signal through. I tried audio probing, R1 is fine on one end, nothing on the other (since it's grounded, obviously), R2 is fine on one end, and very quiet, thin and distorted on the other end. I get the same thin, very distorted sound on pin 2 of IC1 and also on one side of R3. Nothing on any other pins of the TL072.
R2 seems to be the correct resistance, it measures as 390k.However, R1 measures at 0.04 ohms or so, while I think it should be measuring correctly if everything was ok? The bands match up with 10M that it's supposed to be. My DMM doesn't go higher than 2M, but it just shows 0.00 at max setting, and with the lowest resistance setting it shows 0.04-0.06 or so. Edit: I'm dumb, when the footswitch is on bypass, the PCB input is grounded, so of course R1 measures as zero. When I switch the footswitch it doesn't register anymore, which it should, as the DMM only goes to 2M like I said.
There are also a couple of scrapes on the underside of the board where the copper shows through which I was afraid might have ruined the board, but I don't think the signal should stop that early if that was the case.
