Sunflower Cleanup Help
Travis
Hi, I´m start learning about fuzz pedals, I love the sound of some original fuzz faces I try, especially when I turn volume down.
I build the sunflower build and I´m trying with some transistors and different hfe values but I can´t get a good sparkle cleanup fuzz tone.
Some recommendation? Thanks :)
Part numbers don’t equal great fuzz tones. It’s all about how they are biased via the 33k or 8k2 resistors in the original.
Check this article out and test the bias points to see how well your transitiors are biased with your current build
things of note:
sunflower does use a charge pump and those aren't the same as battery power which isn't the same as carbon battery power (sunbeam brand from the dollar store are magic) wrt to playing the fuzz face in a more dynamic manner ... I took the Pepsi challenge on this one and it is one of the few mojo/unobtanium items that holds up
ge fuzz faces with medium or low gain transistors can be a little dark but are generally more dynamic than higher gain
I had more but this post has been interrupted many, many times by work ...
things of note:
OK --- maybe not a MAGIC battery -- but more or less the same point.
Don't forget that Hendrix was using a magic 9-volt battery.....
Nah…you’re thinking of Bob Dylan’s Grandma. Hendrix powered his Fuzz Face with Gypsies, sun, and rainbows…an a little plutonium Roger Mayer stole from the Royal Navy…
I use two different transistors for my Sunflower: MP20A and GT402B. Following typical Fuzz Face requirements, the MP20A is within the 80 hFE range and the GT402B is within the 110-120 hFE range. Ends up sounding pretty damn good. So don't be afraid to use different transistors to get different results. :D
