Sunflower Fuzz troubleshooting
CarloG93
Hi people, this is my very first post here as I just completed my very first pedal build and, surprise, it does not work eheheh, so I'm hoping some of you can help me to identify the issue(s)
I picked up a sunflower Fuzz as I thought it might have been a good place to start. I have very little experience in soldering and none at building pedals.
Now, when testing the pedal the LED doesn't turn on.
When the pedal il on, there is no difference in sound but the only thing I can ear is a tapping noise when the enclosure touches any other pedal on my board or when I press the switch so I'm guessing I also have a problem with the ground as it looks like is extremely microphonic.
I'm attaching some pictures of my build (not for the faint-hearted, I think I've butchered the board) so you can maybe see where the problem might be. Are all the connections in the right place and is it just a problem of poor soldering skills or did I also put something in the wrong place?
Thank you in advance for your help, you are my only hope.
Cheers,
Carlo
Hi guys, hope you're all good. Sorry for the absence, I took my time reflowing the circuit and making better connections. The pedal is still not working tho but is different from the last time:
- no more grounding issues, the pedal is quite silent and no more microphonic
- I got clean signal both when the pedal is off and when is engaged
- this time the volume knob seems to be working properly, although I get a loss in volume when the pedal is engaged and the volume is cranked
- LED still not working.
One of my guess is that I might have fried the diode while soldering, they're heat sensitive and I think I might have applied too much heat. I measure 9.25v on the diode's anode but only about 0.11v on the cathode.
For the rest I'm pretty clueless on what's going on
