I actually like the Mod Podge Dishwasher safe glue better than the original glue. There's still a learning curve with the whole transfer process, but it seems more forgiving than the original W1+ glue.
Here's the last pedal I built using the Sunnyscopa film-free waterslide decal paper and Mod Podge Dishwasher Safe glue. Awesome pedal by the way.
Thanks! I haven't tried transferring to bare aluminum, only Tayda powder coated enclosures. It's important to first prep the enclosure surface. I do a quick wipe with alcohol soaked paper towel beforehand. The last few times I used the film-free decals, I went to FedEx Office and used their laser printer/copier. I've had to experiment with the paper thickness settings to get the proper amount of ink. There's a Zen to how much Mod Podge to apply; too much, and it's messy and doesn't transfer properly; if you don't use enough, there's nothing in between the enclosure and the transfer sheet to grab onto the ink, plus it's hard to slide the sheet into proper position. Also, I try to leave somewhere between 1/8" to 1/4" of the sheet overhanging towards one end of the enclosure so I can grab it to peel off.So I bought this dishwasher save Mod Podge, and tried it with the Sunnyscopa film-free laserjet paper. It didn't really work, I got less than 50% transfer of toner to the enclosure. I was using a bare aluminum enclosure that I'd sanded with 180 grit sandpaper, using an orbital sander. I followed the same application process I described here, using the Mod Podge instead of the Sunnyscopa transfer aid. I did a 15ish minute drying in the toaster oven at 225F.
After that failed, I re-sanded the enclosures and used the GW1-PRO glue, and got a perfect transfer. (The GW1-PRO has generally been pretty good for me on bare aluminum enclosures).
Your pedal looks great, you clearly got 100% transfer. Did your process differ compared to what I described?
I do believe there may be something to the hair dryer treatment. The hot air is very direct on the transfer sheet. I can't actually see it happening, but I'm pretty sure the direct heat is releasing the ink onto the enclosure. I've had some failures with the hair dryer method, where I wasn't holding it close enough and/or moving too fast, but after some trial and error, I believe I have a fairly solid methodology to it. I always have some acetone ready for the inevitable screw-ups, but most of the time it turns out decent. You may want to give it a shot.You used a hair dryer, where I used a toaster oven, but unless you managed to hit some magic "Goldilocks" temperature, I don't feel that's a major difference.
I have a heat gun too and it is way too hot for this. It would melt the plastic transfer sheet and probably damage the powder coating if applicable. You can actually light a cigarette with a heat gun. That's hot!I used to use a hair dryer back when I first started doing this (with the W1+ glue). I switched to the toaster oven just because it's easier (literally set it and forget it). What do you think about a heat gun versus the hair dryer?
1. I do squeegee the decal quite a bit, but I try not to overdo it. I repeatedly dip the squeegee in water to help with the flow. Also, I use distilled water, which is supposedly important for proper adhesion.I just tried the hair dryer on another sanded bare aluminum enclosure. This wasn't a perfect trial, since my wife's hair dryer literally died after about four or five minutes of use. (Looks like the power cable insulation had worn down enough to expose both conductors - made for a nice display of sparks!) Since I only got about half the time I wanted with the hair dryer, I went ahead and baked it again, this time at 300F for about 15 minutes. Unfortunately, I got very little toner transfer again.
It made me think of a couple more questions for you:
- After you apply the waterslide decal, do you squeegee it to get out all the excess Mod Podge? I habitually squeegee the heck out of the decal with the Sunnyscopa glues. As I was doing that with the Mod Podge, I was thinking, maybe I'm getting rid of too much?
- After the initial drying round with the hairdryer - I know you let it cool down completely. Do you leave it alone just long enough to cool down completely, or do you let it sit even longer? (What made me think of that: the directions say two hours between coats and to let it cure completely for 28 days before putting in the dishwasher.)
I have had this issue with the w1+ glue on various powder coated finishes. Some finishes are so slick I have had adhesion issues where the glue won't spread evenly and this caused issues with toner sticking. The raw finish seems to soak into the enclosure and I've not had a single adhesion issue with these.IME the W1-PRO glue doesn’t work well on powder coated surfaces, but is pretty good on raw aluminum. So there’s definitely a surface-glue compatibility dimension to this.
In the meantime, I’m making one more bare aluminum attempt. After reading some random stuff about Mod Podge curing, I decided to try a longer bake at a lower temperature. I did a full hour at 175F. And I’m also going to let it cure at room temp for at least 24 hours before I peel off the film.
i tried the GW-1 Pro on a powder coated enclosure from LMS. applied glue directly to the decal rather than the surface of the enclosure, baked at 225F for 10 minutes, cooled completely and transfer was perfect.Hmmm, I’m about to order some cheap powder coated enclosures to try on, since the bare aluminum is starting to look increasingly suspicious. IME the W1-PRO glue doesn’t work well on powder coated surfaces, but is pretty good on raw aluminum. So there’s definitely a surface-glue compatibility dimension to this.
I wish I’d taken pictures of my botched attempts, but I’m pretty sure this most recent attempt was noticeably worse. I remember feeling like I had 50ish% transfer on the first attempt, and maybe 10% most recently. My thinking is, more heat seemed to be worse, so I’m going in the opposite direction this time around.
Printer toner I suppose could be at play, but I’d assume that since my toner works with the Sunnyscopa glues that it should be ok.![]()
Glad to hear that worked for you. I know that going to FedEx Office and getting the printer settings straight to achieve optimum results is a bit of a struggle too. It seems that more ink printed to the transfer sheet produces better results.i tried the GW-1 Pro on a powder coated enclosure from LMS. applied glue directly to the decal rather than the surface of the enclosure, baked at 225F for 10 minutes, cooled completely and transfer was perfect.
i have since done three additional bare aluminum enclosures with perfect transfers. i think that the key might be the direct application of the glue to the decal itself rather than the enclosure. that's really the only variable for me between these recent successes and the prior failures.
i do like the idea of the DSMP as it's readily available. i'm barely dented this bottle of GW-1 Pro though so that might be a battle i save for another day.
