I have to ask what is going on with the resistor leg sticking out of the pad below the 9v power pad
If it thuds, there is a bad joint!No the pedal works fine. When I switch it on, It thuds, gives a little reverb and then is fine.
Did you check for DC on the output? Can also try removing the LED and see if that kills it.
If the output cap (1uf) is electrolytic try replacing it with a film cap (even of a lower value just to see if it helps). I’ve solved lots of my switch pop problems replacing electro output caps, they’re prone to leaking DC.
(I can’t open the build docs on my phone, I’ll check on my laptop later)
