Popping Issue of M-Wave Mini Universe
slammer88
I Got this m wave mini universe reverb pedal some time ago. It sounds absolutely killer, but there's a problem with that lts been there since the beginning and lots of people also experience it.
When engaged, it pops! It pops and introduces this into the reverb sound. The weird thing is, the longer the pedal stays active, the lesser this popping effect becomes when switched on and off. It makes me think of a capacitor issue, but seems like lots of people complain about it on YouTube comments. There is also a slight delay of the sound like 10-15ms.
I've solved this popping by soldering 2.2k resistors from in to gnd and out to gnd on the switch, I got no tone loss, but the delay is still there. I know its pretty low, but from 500k to 10M resistors did not work at all.
I've done a video about this; I'd like to hear your opinions as well. There seems to be a weird connection of 3DPT that actually causes this popping and delay at the same time. Is there any workaround to fix this do you think?
Can we have pictures of the insides? Depending on the room you have to work with, it could be easy to try some solutions mentioned in this thread. A pedal that small might be a fair bit more difficult to add stuff to than a diy pedal with discrete jacks and power connectors and all that jazz.
I thought the video would be useful but there you go, it's quite a tight fit as other Chinese pedals. And it's a bit smaller 3pdt switch there compared to regular ones. Lug gaps are smaller.
I think ill remove the 2 resistors that are 22k now, as on my pedal board connected with others, they seem to lose a bit of a tone. It was good individually tho.
Another thing that caught my attention is that there are 6 or 7 polarized caps all around the circuit and all of them are 100uf/16v. It's well possible indeed, or a coincidence, but I have seen tons of layouts so far yet none of them had this much "same" valued caps. I somehow thought that would these Chinese guys go cheap and put all the polarized caps the same. Because this DC voltage accumulation on output and popping due to DC offset are seemed to somehow related to capacitors.
