Lytt Effects
So I'm looking at adding a switch to go between symmetrical and asymmetrical clipping, specifically in the Cast Iron overdrive. I've attached a schematic of the clipping diodes, and just want to make sure I'm thinking about this right.
First, if I want to just make it asymmetrical clipping, can I omit any one of the diodes and be ok? Jumper required? My plan was to omit D4.
Second, if I wanted to have the option for both and put them on a switch, I was thinking I could wire a DPDT ON/ON switch with the leads going to D4. On one side of the switch it will insert the diode, when flipped the other way it will omit the diode. Again, jumper required here on the switch, or just leave it empty?
