I don't own any JHS & don't plan too!And if you bias it right it's a Superbolt?
Just wondering whether this is literally just a Superbolt with fucked up biasing.
grateful for this one! i love messing with biasing.Almost, but not quite.
It has two sets of bias controls that can be selected by the Tacos! toggle switch.
Tacos switch up = Fucked up biasing (TACOS!)
Tacos switch down = Proper biasing (no tacos....)
It also has the correct Gain toggle switch that was incorrectly traced years ago.
This project will be replacing the Super 64 since you can omit the Tacos switch and build the straight overdrive if you'd like.... no need for both.
I love how remorseful Josh was that the Designer up & died on him so he didn't know what the Parameter was so with clever planning , they measured it!!!That's exactly what it is but the Tacos version has the Gain switch deleted also!
Robert has made it a 2 for the price of 1 pedal!
@Robert am I correct in seeing that the bias of each of three stages is switchable between two trimmers? I read that it’s only Q3 that’s misbiased on the taco thing, so this should definitely be more interesting for experimentation in that case!
noticed that too. drifted over it so casually.I love how remorseful Josh was that the Designer up & died on him so he didn't know what the Parameter was so with clever planning , they measured it!!!
Does anyone have the actual bias's of a Superbolt V2?
If no one else posts them first I'll get them shortly.
Someone over in that same thread on TGP said that JHS told them to set all three trim pots to 9 O'Clock for stock Superbolt bias. My guess is that was a miscommunication and they actually meant 9V, which would make sense.
wanna get same one dayView attachment 71454
Pixelbuddha's identity mockups https://pixelbuddha.net/search?text=identity+mockup are a game-changer for my branding projects! With their diverse range of templates, I can visualize brand identities with precision and professionalism. From sleek corporate designs to artistic concepts, these mockups elevate my presentations and ensure a cohesive visual identity. Pixelbuddha is my go-to resource for impactful branding.![]()
A tunable pedal. Perhaps it should be called the Tuna Taco?@Robert am I correct in seeing that the bias of each of three stages is switchable between two trimmers? I read that it’s only Q3 that’s misbiased on the taco thing, so this should definitely be more interesting for experimentation in that case!
