mastermachetier
Hello all,
I am looking to see if any of the pre drilled enclosures would fit a Ton Vendor MKII or a twin face
Any ones you think would fit a TerrariumKeep in mind the twin face is a 2 knob + 1 switch, and the 3 knob will have holes drilled for pots, not switches. Which just means the hole where the switch is will be a bit wider than it needs to be. It should still work though--you may or may not need to find a larger washer for the switch if it's not covering the hole.
nope, you would have to get it custom drilled (I can give you the drill coordinates if you'd like)Any ones you think would fit a Terrarium
That would be awesome. Any where you typically get these drilled ?
SIDE | SIZE | X pos | Y pos |
| B | 9.7 | -15.2 | 5.75 |
| B | 11.7 | 0 | -4.4 |
| B | 9.7 | 15.2 | 5.75 |
| A | 7.2 | -20.32 | 38.1 |
| A | 7.2 | 0 | 38.1 |
| A | 7.2 | 20.32 | 38.1 |
| A | 7.2 | -20.32 | 12.7 |
| A | 7.2 | 0 | 12.7 |
| A | 7.2 | 20.32 | 12.7 |
| A | 6.55 | -21 | -12.7 |
| A | 6.55 | -7 | -12.7 |
| A | 6.55 | 7 | -12.7 |
| A | 6.55 | 21 | -12.7 |
| A | 4.6 (LED, you might want to adjust depending on what you're using) | -15.24 | -27.3 |
| A | 12.2 | -15.24 | -45 |
| A | 4.6 (LED, you might want to adjust depending on what you're using) | 15.24 | -27.3 |
| A | 12.2 | 15.24 | -45 |
your builds look awesome thanks! also picked up two of these seed boards so i'lll see how these go. i have a back log of 10 pedals to build lol trying to aquire all the parts nowTayda Custom Drill Service. Turned out great for me.
Please note those measurements are for a powder coated enclosure and already include the added 0.2mm they ask for this.
SIDE SIZE X pos Y posB 9.7 -15.2 5.75 B 11.7 0 -4.4 B 9.7 15.2 5.75 A 7.2 -20.32 38.1 A 7.2 0 38.1 A 7.2 20.32 38.1 A 7.2 -20.32 12.7 A 7.2 0 12.7 A 7.2 20.32 12.7 A 6.55 -21 -12.7 A 6.55 -7 -12.7 A 6.55 7 -12.7 A 6.55 21 -12.7 A 4.6 (LED, you might want to adjust depending on what you're using) -15.24 -27.3 A 12.2 -15.24 -45 A 4.6 (LED, you might want to adjust depending on what you're using) 15.24 -27.3 A 12.2 15.24 -45
Also note that there's no hole for the micro usb on the seed, I did it at home and filed it (not that well, for that DIY lookyour builds look awesome thanks! also picked up two of these seed boards so i'lll see how these go. i have a back log of 10 pedals to build lol trying to aquire all the parts now
Hey quick question where did you get l78l054 chipsAlso note that there's no hole for the micro usb on the seed, I did it at home and filed it (not that well, for that DIY look), but you could have it done by them.
hi, i want to try Tayda's custom drilling.Tayda Custom Drill Service. Turned out great for me.
The added 0.2 mm is only for the hole size, as the powder coat adds 2mm of paint (as stated here).hi, I'am also planning
would you mind if you tell me what is Tayda 125b's height and length measurement? I didn't had a chance ordering uncoated enclosure from them, that is why I don't have a chance measuring the exact measurement without the coat.
what i'am curious about is the dimension (length and height) of the sides.The added 0.2 mm is only for the hole size, as the powder coat adds 2mm of paint (as stated here).
For a bare enclosure you just subtract 0.2 mm to the measurements in the "size" column. The X and Y coordinates would be the same.
ow s#!+! how could i forgot the datasheet. Thank you.
You’re welcome Dan! Always happy to contribute what I can.@SYLV9ST9R just a note, it was incredibly nice of you to share all this info. Thanks sir.
