SOLVED Texel works for 1 second
jcpst
Here’s the problem- when I flip the bypass, it works for a second then quickly fades out. I’m attaching a short audio file that demonstrates this.
I tested all the components before I added them.
If I had to take a guess, it would be on either of the transistors. What I don’t know is what to do about it if that’s the problem, besides just trying out other ones until I found something that worked.
View attachment Texel issue_1.mp3
Solution
I'm not familiar with this layout but I don't see an onboard LED, which makes me wonder if those -/+ pads at the bottom of the board are raw VCC and not the low side of an LED/CLR...
And if that's the case, the breakout board is shorting your 9V supply to ground when the pedal is active.
I'd clean off some of that flux on your board first. Then go through the checklist: is everything powered with correct voltages? Are all your components correct and oriented correctly?
Something is up with the voltage. I’m getting fractions of a volt from the terminals on the power jack.
Just as a sanity check, with the circuit removed from the jack, the jack was getting 9.4V. I inspected for shorts and haven’t found anything yet.
Actual lumbergs from Stomp box parts. I tried another, tested the jack by itself, then connected it to the circuit. Same issue.
This issue is a new one for me! I can bypass it as many times and as often as I want. The pedal will pass sound and the controls seem to behave right, but it will just fade out right away.
my bet is the footswitch daughterboard... Could have a weird piece of leftover wire lead in between stuff or possible solder bridge... .Thats why I just never use them because i'm heavy handed with the solder already...
That is bizarro! What kinda jfet is in there?
2N5457. From stomp box parts- I was going to try my other one but of course I just lost it. I socketed both transistors and then tried some others with the same result.
Cap in the power section is either reversed or bad
Caps appear to be oriented correctly. Since caps are cheap and easier to replace I probably try that first
tested new caps and added them, gave the board an extra alcohol scrub, tried the other JFET. Still the same results.
I gotta leave the bench for the night, but I think the next thing I’ll try is a switch w/o the breakout.
Solution
Looking at the trace that appears to be what’s happening.
Yep! I recycled the case- the faceplate went over the LED hole- I decided “meh I don’t need an LED” and then didn’t think anything of it.
Thanks Robert!
