xefned
I very carefully built "The Thing" from DeadEndFX, and the moment I plug in 9v, the LEDs light up. They're supposed to pulse with the guitar attack—adjustable with the trimpot. And they do at certain settings, but they never go fully dim.
The 3 on the left are brighter than the 3 on the right. That might be normal since they're 2 pair of LEDs in series (not parallel.)
The only fucky thing I did is sub the 2k rate pot with a 5k pot w/ 3k3 resistor on the outside lugs.
The rate pot seems to have no effect. So perhaps that resistor trick doesn't work in this configuration.
The drag part is turning the full 25 rotation trimpot, I never reach the 6.2v specified. I can adjust only from 4.38vDC to 5.37vDC
I'll replace the rate pot (currently 5k +3k3Ω resistor) with a proper 2k pot but I'm not sure it'll make any difference. As is, the rate pot does f**k-all. So I might as well try.
If anyone has any thoughts or suggestions, then thank you. Otherwise this is just a report from the field.
