This really is a resistor (warning SMD content)
p_wats
On the rare occasion that I try SMD work it always amazes me how tiny the parts are. Im sure this is old hat for many of you, but this is a 0603 resistor (actually not that hard to solder with normal tools).
I'm hoping to do more SMD, so let me know if you know of any interesting projects!
I have no comment because I get my SMD boards assembled by people with the proper machinery. :D
Ha. I don't blame you, but I kind of like doing it. I have a hot air station, but just use my regular iron with a fine tip. Just some flux, tweezers and a dab of solder here and there and it's pretty quick (no leads to cut and send flying everywhere either).
I just designed and ordered a simple circuit board that uses a mix of both through-hole and SMD, but the SMD are one size bigger (0805), so it's a bit easier.
If I had a hot air station I might consider it. I use 0402 a lot though unfortunately hahah
I have a hot air station but I really don't use it to solder components. It only gets used for three tasks...
Degooping
Desoldering SMD ICs (when I want to salvage them)
Heat shrink tubing
I use my regular soldering iron for pretty much all SMD work.
You have to be careful using hot air for SMD components, you'll blow em across the room. ?
Yeah, I was a bit disappointed at how little I've been using the hot air station, but my heat shrink game is on point now!
There was a time I was about to dive into DIY modular synth builds, which would necessitate more SMD, but I've been able to resist the temptation so far.
