Chuck D. Bones
Circuit Wizard
Try it, but you'll probably have to adjust Q2's bias. Increase or decrease R8 as req'd. I think we want Q2-C to be around 5V. You can adjust Q2's brightness with C2.
Thanks so much, Chuck! I had begun to lower the value of C8 just to bring down overall gain, but I think I only brought it down to 10µF.I'd be interested to see that too.
Referring to my schematic, Try reducing C8. Q2 does most of the heavy lifting. Making C8 smaller reduces Q2's gain at bass frequencies. Try 4.7uF and proceed from there. Something else to try is to put a 1K trimpot in series with C8 and use that to dial-in the gain.
C5 limits the top-end, so you can make it brighter by reducing C5.
VOICE does two things. With VOICE at zero (7:00), you get maximum bass & maximum treble. As you rotate VOICE clockwise, the bass thins out. For most of its rotation, VOICE is a Bass control. Somewhere above 2:00 VOICE starts to cut some of the treble. C4 controls how much bass & mids get cut when VOICE is above noon.
...so I'll try to cherry-pick the higher Idss ones going forward...
