Chuck D. Bones
Circuit Wizard
Deja Vu.You have been there before:
looks like something similar but slightly different is what Chuck did on his pink-purple (fuchsia fuzz) with the clipping control, could be tried here too I’d think.Sorry. Current Limiting Resistor.
Oh yeah, I see that. Cool. Good catch.looks like something similar but slightly different is what Chuck did on his pink-purple (fuchsia fuzz) with the clipping control, could be tried here too I’d think.
So how would we need to adjust when using mmbf4393 instead of the 2N5952 Sir Chuck?Try the stock build, it's pretty sweet as-is. The only mod I'm considering is trying other JFETs. That would require tweaking the source and/or drain resistors to get the right bias point. It's likely that BJFe/Bearfoot has to screen their 2N5952s for Vp.
The size of the soldering iron tip?So how would we need to adjust when using mmbf4393 instead of the 2N5952 Sir Chuck?
Asking for a friend....![]()
Awesome that will be much appreciated! Cheers Chuck!Most other JFETs have lower Vp, so you'd need to reduce the source resistors (R4 & R14). On my breadboard using 2N5952s, Q1's drain voltage is 6.90V, Q2's is 5.82V. These are not magic numbers, just ballpark. That's what I got using stock resistor values and it sounds good to me. I'd shoot for 6V on both JFET's. To bring Q3's gain back to the stock value, you'll need to increase R15 so that their parallel resistance is 1.6K.
I'll give it a try using some MPF4393's I have and report back.
