nondiatonic
I just assembled my very first pedal, and I have now experienced the "first pedal rite of passage": it didn't work.
Initially I thought there was no sound at all (LED worked), so I built an audio probe and began following the audio path. By doing this I realized that there was audio coming through the output, but the volume was so low I had to damn near max out the volume on my amp to hear anything. Transisters are 2N3903. I didn't measure them before assembly (I wanted to socket them, but I didn't buy the correct size sockets). I boxed it up, so I haven't checked the film capacitors with the audio probe because they are flush with the PCB--I'm hoping to avoid needing to desolder the power jack (next thing to build will be a test box, so I can avoid this scenario).
Some things I noted while probing the audio path (these phenomena may be normal, but I'll list them just in case):
- Q3 emitter not as loud as I would have expected
- Gain Pot:
- Lug 2 appears to work as intended (gain increases as it's turned up), but it seems quiet throughout the entire range
- Lug 3 gets very loud very fast as I turn the pot down
- Tone Pot:
- Lug 1 gets very loud very fast as I turn the pot down
- Lug 2 seems to act like a volume and gets slightly louder as the pot is turned up (though fairly quiet throughout entire range)
- Volume Pot:
- Lug 2 is extremely quiet at full and turns down quickly to nothing
