Today on the Breadboard: The Power Face
That's awesome. What is WW on VR1? I don't know enough about tube circuits to know if this is an april fools day prank but this looks super interesting. :ROFLMAO:
R5, R7 & C5 were changed. R8 & the notes were added.
I lowered V2's plate current. Added R8 because we probably don't need 150Vp-p output. That would destroy most pedals and transistor amps.
One could replace R5 with an output transformer and drive a speaker for a little over 1W output.
OK, I have a confession. I initially posted this as an April Fools prank. On reflection, it could be made to work either as a dirt pedal, headphones amp or practice amp. If all we want is a pedal, then we don't need a power pentode for V2. Instead, we could lower the B+ and use a small signal pentode like another EF86 or a 6AK5. If what we're after is a headphones or practice amp, then we just replace R5 with an output transformer and put a VOLUME control up front. The FUZZ pot can be a fixed resistor that gives us the desired maximum gain.
BTW, here's a vintage guitar amp circuit that bears a strong resemblance to the schematic I presented above. I was not looking at or thinking about this circuit when I drew the one above. RV1 is VOLUME, RV2 is TONE (treble cut) and RV11 is a kind of BASS BOOST. Some of the resistor values are suspicious, like R3, R5 & R7 for instance. Maybe they're correct.
