Just finished my Timmy/Tommy with an LM1458N, and after a little troubleshooting it's up and running fine. However, I expected that with the gain down and the tone cut controls turned down it would be essentially a clean or slightly dirty boost with flat eq, and as I turn the gain up, I have the option of then removing or retaining as much bass and treble from the original signal as I want. Instead, even with G+B+T on 0, and volume set for unity, it sounds noticeably muffled at the top--kind of a wet blanket effect. This is ok at higher gains, but not when I need some sparkle to come through. Any suggestions for where the trouble might be, or how to remedy? TIA, Ben
