Tone Vendot MK1 battery only build
AR-1N
I'd like to build a battery only positive ground version of the Tone Bender Mk1 (using the Tone Vendor MK1 pcb). Therefore I want to leave out the voltage inverter.
So I'm basically asking what should I do?
- Connect the battery negative to + and the battery positive to - on the pcb?
- Jumper the Voltage inverter pads 1 and 5?
- Leave out C5 and C6?
- I'm not going to use the LED either so I can leave out the R10 as well?
What about the wiring, do I need to change something (I'm referring to the build doc)? I assume not.
Anything else I may have forgotten to mention?
Any other than that I just follow the instructions.
