I’m currently using an ehx howlitzer as a pedalboard amp into a 1x12 or this thing I wired up to allow headphones for both right and left.Very intriguing. Would like something like this for my 2x12 can that is hanging out in my room.
Or turn my Dream65 into a real amp...
Absolutely, assuming I have 19v between the 2 larger wires I am going to assume the little blue one doesn't matter. I found a bit about these Dell power supply. The little wire allows the computer to communicate with the charger. I am curious if there is any benefit to keeping the ferrite bead? I am planning on snipping this wire down as short as possible.I would verify with a multimeter
Are you using a preamp and buffer?So I’ve got a 3118 board and as soon as I hit the strings audio goes away (can hear a thump thump thump) but audio comes back and I can hear the chord sustaining. Once in awhile it’ll play the audio while I’m playing. I was using a 12v 1.5a supply and a 9V 2a supply when I tried it. Any ideas on what would be causing this
I've posted various options for preamps and posted the alterations to the schematics in this thread to increase the output level. But, I like the volume-only circuit in post #146 the best. It includes traditional "bright caps" for treble boost. Second best is the marshall style EQ post #161. But, these require making a PCB yourself. It's hard to beat the simplicity of the tone tweq board, post #155. And for simple power-on delay to avoid a pop on power up, add a 22uf cap between the mute pins on the tpa3118 board (post #160).Reading through all this I’m debating how I want to set up this little thing. So I currently have an exh howitzer 15w, it works well but I have a few issues with it.
It lacks a headphone out, which I have fixed by making my own in a seperate box but now it takes up more room on my board and an extra cord.
Lacks an aux input, same situation as above for the fix etc.
So those two things really made me want to build a little pedal board amp of my own.
Curious if anyone has any input on these thoughts.
It’s going to be used in a pedal board. I have a few different pre amp pedals and a 6 band eq, I don’t see it really being in a situation where I don’t have a preamp pedal before it. But I was thinking of putting a boxandall eq in for a preamp, and just kind of debating. Actually have a strip board version of it hanging around I could fit in a 1590bb with the power amp and necessary jacks. Just debating if it’s worth it and since it’s a clean preamp do you think preamp out and power in after would be necessary for pre amp pedals etc. other option I thought about doing was just setting the boxandall up as true bypass and it’s there if I want to use it or I can just bypass it and use either my Doxie, sheriff or cobbler as the pre amp.
Mainly wondering if there’s any real downside to the bypass setup, seems most logical.
So I’ve currently been playing around with an untweaked box and all. I can make a vero etc as opposed to a pcb if I want to try the others. Might be a good project as I’m interested in getting familiar wit dip trace. but I do feel like the vero might add some noise. I like the tone controls of the box and all I may do some more experimenting with the component changes you recommend.I've posted various options for preamps and posted the alterations to the schematics in this thread to increase the output level. But, I like the volume-only circuit in post #146 the best. It includes traditional "bright caps" for treble boost. Second best is the marshall style EQ post #161. But, these require making a PCB yourself. It's hard to beat the simplicity of the tone tweq board, post #155. And for simple power-on delay to avoid a pop on power up, add a 22uf cap between the mute pins on the tpa3118 board (post #160).
The component changes are important. Signal level is not high enough otherwise.So I’ve currently been playing around with an untweaked box and all. I can make a vero etc as opposed to a pcb if I want to try the others. Might be a good project as I’m interested in getting familiar wit dip trace. but I do feel like the vero might add some noise. I like the tone controls of the box and all I may do some more experimenting with the component changes you recommend.
Your board looks to be this one with rebranding added and these are fake...The 3116 is fairly good, I've gigged with one of these, but they are substantially larger.
