First post, discovered this thread when looking into building a Class D guitar amp.These amps take line level (about 2V peak to peak) for full volume. Guitars and pedals are instrument level (about 200mV peak to peak). You must use some sort of preamp that will get up to line level. I've posted multiple solutions in this thread.
Edit: Oops, I misread your question. You have the pot connected wrong... Draw up what you have done and post some pictures.
These things need a buffer in front of them to get any sort of usable volume.TPA3118 has an input impedance of only about 30k ohms....nowhere near the 1 meg of a typical guitar amp]
Any idea when? Asking for a friend...It's going to be a pedalboard-mounted power amp project.![]()
FWIW, I built a small LPB1 buffer board with a trim pot and placed it inside a 1590BB box using one of these small amps. It works really well with the output from the Sushibox tube builds.Nothing's popped up lately with respect to these boards. I've recently completed a couple of Sushibox builds (tube driven preamps) and am curious about the relationship btw the output of the tube preamp and the input requirements of a typical Class D amp or PA mixer. I understand both want to see a line level signal which is what. . . 2 or 3 volts peak-to-peak? Also, impedance matching. . . tube preamp output impedance is around 38K. Is that good, bad or indifferent with respect to the input requirements of amp/mixer?
I have had the power amp with the buffer/boost built for a few years and am just noting it works well with the output of the tube preamps. They work well at either end of my pedal chain, so I don't think that is too surprising. There probably is enough output from the Sushibox pedals to not need the buffer.Hmmm? . . . that's a booster isn't it? A tube preamp is putting out 20+ volts isn't it? Don't you need to reduce the output of the preamp? That can be done with the Master Volume. But to broaden the useable sweep of the MV I was wondering about adding a resistor or voltage divider network in advance of the MV. Maybe on a toggle so you can switch btw use with a Class D/mixer or in an FX loop in a conventional amp.
Not the help you need. I looked at the datasheet, and it says “grounding required” under the input terminal descriptor. I‘ve used many Meanwell supplies, mainly ones in perforated enclosures, and have a strong memory of their having a green screw for ground on them, but the datasheet, beyond that mention of grounding required, doesn’t have any details. I didn’t go to the Meanwell site to look at their manuals section—the datasheet refers this for installation, so it may be answered there. If still no sure answer, the grounding the enclosure it’s in would be my take.Anybody up to snuff on power supplies? I hooked up my little TPA3118 amp board with just 19vdc 3A laptop power supply and IN/OUT jacks . . . no volume pot or related caps, etc. as shown in the layouts above. Talk about HUMMMMMMM?!? What I've read is that most laptop PSU's are not grounded and that is the source of much of the noise. I was looking at the Meanwell EPP-200-24 which is an open frame PSU that could be placed in the same enclosure as the amp board and fed with 120vac, but none of the hook-up pins show a dedicated GRD for a 3-prong power cord. Any words of wisdom on this subject would be appreciated.
I haven't had any issues with the 3118 or 3116 in terms of noise. It can vary a little between power supplies, but I've found the higher wattage amps to be terrible for noise - to the point of not using them, lol. I have a couple around that will need proper transformer based power, but as far as laptop powered boards, it seems like the 3118 and 3116 are they way to go.Anybody up to snuff on power supplies? I hooked up my little TPA3118 amp board with just 19vdc 3A laptop power supply and IN/OUT jacks . . . no volume pot or related caps, etc. as shown in the layouts above. Talk about HUMMMMMMM?!? What I've read is that most laptop PSU's are not grounded and that is the source of much of the noise. I was looking at the Meanwell EPP-200-24 which is an open frame PSU that could be placed in the same enclosure as the amp board and fed with 120vac, but none of the hook-up pins show a dedicated GRD for a 3-prong power cord. Any words of wisdom on this subject would be appreciated.
I looked at bunch of these and chose the TPA3118 cause it seems most people have positive reviews. I am curious about the 100W TPA3116 as well for more volume or maybe the TPA3110 for a little practice amp.
