well.....I'm building a Madbean Pastyface which is a Fulltone Soul Bender
Just getting into the Fuzz thing and could use advice on choosing and sourcing PNP trannys.
If I could punch you, I would...well.....
I would use the internet....
ussian PNP, probably MP21A or MP42B, I don't recall as I favour the readings not the package. A lot of Russian stuff is 50-80 hFE and low leakage.. I got mine from Bu
Nah. that's some kind of glue residue. All my other 100u electros were big 50v ones so I used this one. Tested it first and it's nearly dead on 100u.The big blue cap on the right looks burned??
Small bearIn the meantime, is there a short cut to getting transistors that ARE in spec?
Buying a matched set from somewhere (e.g., small bear).In the meantime, is there a short cut to getting transistors that ARE in spec?
I was going to use <drum roll/ cymbal crash> instead of ;-)If I could punch you, I would...
