Not my absolute cleanest gut jobs, but when you’re trying to cram mod boards in, things get a little messy. The Loon build is using an intelligent relay board to switch another 10u cap in series so that you can double the rate either briefly or extended. The OCD is using a board from Tayda and has a clean blend board (Nucleonfx fusion based on the old Schooner circuit) and a charge pump included so no need to buy a special power supply to run it at 18v.
